01.20.2011, 01:27 PM
On just about all my setups (which use Spektrum), I also run a capacitor in the CH3 slot. Spektrum receivers do tend to be finnicky - maybe they just don't like the little switching noise present on the power line. You could also wrap the throttle cable a couple times through a ferrite donut to inhibit that noise (may have to temporarily remove the connector to do this).
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
01.20.2011, 01:35 PM
Spektrum receivers do tend to be finnicky. You could also wrap the throttle cable a couple times through a ferrite donut to inhibit that noise (may have to temporarily remove the connector to do this).
Good Idea, I have a Turnigy BEC I Blew out with a ferrite ring. That will be a lot cleaner looking going through the ring than a zip-tie anyway!
Did you have any problems when you were not using the Caps? and what spec cap are you using Brian?
Thanks - Sean
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
