01.21.2011, 03:59 PM
Must go home and check mine - looks almost the same... Although you are missing the RC-monster front top plate...
I'm sure Mike would sell you one... Personally I'd go for a 5mm shaft with this - I've snapped a 1/8th shaft on a CRT.5
Candyman2
Candyman2's Avatar
01.21.2011, 06:00 PM
ah, I think i'll leave the top plate as is.
Finally got the kyosho 46 on the diff, had to make a little collar to take the 8mm spur up to 10mm for the bearing, then had to trim the spur to get it in. Then had to enlarge the chassis cut out by 1mm so it doesnt catch.
silentsnow31802
01.22.2011, 04:45 AM
Looks very nice!
Whats the benefit of running that spur?
