the light weight gears didnt work for me. Yess they were slightly hardened but the contact surface area was terrible as they were so narrow. I was still going through those gears every 10-15 runs. But depending on how your savage is set up will wear the gears differently.
Considering mine was very nose heavy and struggled to wheelie, i could drive every where at full throttle not worrying about flipping, so my gears wore extra quickly...
Thanks, is that motor cradle piece removable from that mount? Could the mount be made to work with the 1717 at all?
I think the only part that can be reused is the bottom plate of the FLM mount.
The front part must be replaced by a taller one and with the M4 holes, the back support must be replaced by a new (custom) one to fit the 1717 diameter.
Did you shim the gears so that there is no movement from side to side?
