Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Jahay
01.31.2011, 09:30 AM
No the helical gears of the vorza definitely wouldnt hold up...
MAYBE If they were in an alloy diff case with no flex... but i wouldnt try it...
OK GUYS! I REALLY NEED TO GET MY DIFFS MADE UP!!!
and need to just ask some final questions to see whether this will work...
Firstly... i think bocas are awesome.. .but im not replacing 2x $20 bearings every time i open up my diffs! So that is a no no for me...
I ideally want to get rid of the silly thin 10x16x5mm bearing...
So what will definitely be used???
The Spider Internals - Hot Bodies Hardened Steel Differential Gear Set [HBSC8101-1] As it seems these are the toughest on the market that work with the bulks we need to use...http://www.amainhobbies.com/product_...ntial-Gear-Set
RING GEAR - HPI Bullet Proof Ring gear
Axles - Stock Super Hardened Hpi Axles.
JUST THE CUP IS NEEDED....
So questions regarding the cup
Regards to The Lightning Stadium Diff Cup (HBC8019). http://www.hotbodiesonline.com/products/en/hbc8019.html
You say that it would accept the:
BP Ring gear, HB Internals, and accepts the 8x16x5mm bearing.
BUT as it is plastic, i just can not trust that it would be able to cope with the high power of a 9-10s Brushless system...
SO ALLOY CUP IS NEEDED
It seems that the only cup that may work is the Lightning Stadium IRC Alloy Cup http://www.innovative-rc.com/lightni...ver-p-209.html
We know it fits in the flux
we know that the BP Ring gear is accepted and the screw holes all line up
we know the hardened spider gears will fit. (what slide in blocks?)
BUT WILL THE OUTPUT AXLES SHAFTS FIT from a flux???
SimpleChamp - Can you tell us exactly which IRC Alloy cases you are using??? You say they work with the spider gears mentioned... But do they utilise some form of slide in block like the savage??? And if so, which ones do you use? You dont by any chance have pictures of everything installed inside the diff cup to you?
Also are the axle shafts you have used, the same size as the SHD Flux ouput shafts???
THANKS A LOT
I think these are the only Q i need answering before i give it a go...
