02.09.2011, 01:05 AM
I guess this can be my next savvy mod after I have figured out the cen arms/hubs/cvds and the lst2 stuff...
Nothing is going to be 100% drop in, so set your punch control for 90% and run 4s lipo if you want the stock flux stuff to last...
I find the humore that after everything is said and done that a bunch of us will have more than 1k in a savage, when a 500 buck cen genesis might just be a better starting point. Stick a 1717, MMM, and 6s in that beast, basically an overbuilt savage anyways.
I will continue my savvy mods, just cause they are fun. Got the hingepin braces made, just need the trunbuckles and a suitable motor and my 15" wb savvy will be ready to roll.
02.09.2011, 12:53 PM
Maybe... I did consider one before I got my original Savage; but parts support sucks for it, so I decided not too..
But really isn't modding the trucks and cars what most of us at rc-monster's forums are about? :)
02.09.2011, 12:59 PM
yes linc... definitely have sunk in way more than $2000 into the savage! closer to $3000 i believe... but prefer the Savage to the CEN
desperate to see how those hinge pin braces turned out!
zero that is true... the support for CEN is pathetic compared... MODDING FTW
02.09.2011, 01:16 PM
Yes it is! That is why I will continue modding my trucks!
Flux Fan
02.09.2011, 05:59 PM
If this STP oil trick fixes the tranny, I don't think there's much of anything else to worry about on this truck. It will be very low maintenance!
Getting a straight answer out of HPI is like pulling teeth, but I would really like to know why they left those two junk gears in there.
02.09.2011, 06:07 PM
I think some RCM hardened Savage tranny gears would do the trick! HINT HINT HINT!
02.09.2011, 06:16 PM
Oh yeah!
02.09.2011, 06:32 PM
OR, instead of sealing the case and running oil inside, maybe just give the gears a nice coat of graphite.
02.09.2011, 06:37 PM
What about some lubricant such as Gorilla Snawt that is formulated not to 'fling'?
02.09.2011, 06:39 PM
oil works better than dry lube
grease flings, no way around that with the kind of speeds we spin stuff.
02.09.2011, 07:00 PM
maybe some of that motorcycle chain lube, there are several different varieties of it. Some of it doesnt fling at all. I dunno.......just trying to come up with something different.
Flux Fan
02.12.2011, 10:58 PM
Option 3 was a success! I am very happy with this mod. Thanks for the tip linc!
The truck has never run so quiet, which tells me there is no more gear on gear grinding inside the tranny. The truck is so silent, even at WOT, that it is hard to believe it's a FLUX.
After 6 runs, I opened up the tranny, and there are zero signs of gear wear. Only down side I can see to this mod is I will need to totally seal up the tranny to keep the lube from seeping out. Those high RPMs fling that stuff so hard that it even slides past the bearings. Pictures tell the story.
I cleaned it up and sealed the top half to the bottom half after taking these pics. Next time I break it down, I'll look into sealing the bearings into the holders and onto the gear shafts. That should prevent the lube from sliding past the bearings, but will not hender the bearings from doing thier job.
02.12.2011, 11:06 PM
that is awesome news... how high is the level of the oil?
Flux Fan
02.12.2011, 11:14 PM
I'd say there is aprox 3/8" of oil in the bottom. Just need enough to get the bottom gear teeth wet, the gear action does the rest.
02.13.2011, 02:13 AM
Attachment 9721Attachment 9722Attachment 9723Attachment 9724
What kind of oil/lube are you using?
Back in the day, Sikeston34m was using stp oil sabilizer. Thick stuff, and it really sticks to the gears. He was not having a leak issue like you are having, and all he did was use rubber sealed bearings. Pretty sure the stock bearins are rubber sealed in the flux anyways.
Glad to hear it is working well, metal gears need oil. I think using some rtv silicone would seal it all up well. I would smear some on the shafts where the bearins sit, and where the bearing contact with the case. And on the case halves too. Maybe just use some bearing grease between the top and bottom cases, so they can come apart easily.
Should make those gears last!!!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
