02.09.2011, 09:44 PM
Originally Posted by josh9mille View Post
I think on the thick end you could have shortened the pin even more and then not drilled all the way through the hingepin brace. It would have eliminated the use for the retainer screw.
Yes, this could be done. However I like being able to remove the pin from that end, the plastic skid does not have to come off for this. If you want the pins out the other way you have to remove it. Just 4 screws and the bumper mounts, but I like the option.
