Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Jahay
02.21.2011, 09:20 PM
Nice write up... are those the stock LST Axles? no mods required? Just use the usual 3mm pin? Does the bolt come with the kit? does it securely hold the extended hex on? or just provide support ?
Thankns
brian015
brian015's Avatar
02.21.2011, 09:56 PM
Thankns
Stock XXL/LST2/Muggy axles without mods - yes. The 3mm pin goes through the axle and the hex - the bolt (normally a set screw) threads down inside the axle and holds the pin in place. I use the bolt because I can tighten down on it better than on a set screw. I bought the bolt at Lowe's.
