02.22.2011, 12:15 PM
Thanks linc for the pics!
Are those turnbuckles made of steel or alloy? just out of curiosity... i wouldnt mind getting them anodised red if they are alloy.
I see you are still using the Savage normal HD axle outputs. Are you having to replace those or are you going to make do?
Linc... is the hex pin a 3mm pin? I want to run 17mm hexs and unsure as to which ones would work with the LST CVD...
They are steel, i would never buy alloy turnbuckles, as they always break on me. At least I can bend a steel one straight.
I am looking for a solution to the outputs, thinking a hotbodies diff will have longer outputs that will fit the savvy diff. I like that the vorza cups mimic the lst cup size, and will be using those on the cen setup.
Not sure on the pin size, I will find my metric calipers and see. I know that any lst hex will fit (of course) and sportwerks stuff fits too. I run sportwerks 17mm hexes on my lst2. You can also make the cen 23mm hexes work with a little filing on the backside (my 6x6 lst has those). Check out lstforums, they should have a list of the hexes that will work. The critical dimension is the distance from the pin hole to the outer bearing face, I know ofna hexes will not fit, as they have the hole in the hex spaced differently.
