coreyfro
02.22.2011, 02:50 PM
Do you have that setup right now (minus battery) and an Eagletree? If so, you could run whatever battery you have to get a ballpark figure.
I wish I had an Eagletree. I was just hoping for a ball park.
The battery I am currently looking at is:
http://www3.towerhobbies.com/cgi-bin...?&I=LXYKT4&P=7
7.4V 4200mAh 30C (Max Burst Rate: 60C/252A)
I think that's more than enough. Before I was looking at a 3300mah stick-pack, but this one is only 30 grams more, and it will allow me to lay my pack flat. Getting a lower CG was part of the desired effect and that 30 grams lower might be better than the alternative.
scarletboa
scarletboa's Avatar
02.23.2011, 02:52 AM
that battery should run just fine on your setup.
