03.03.2011, 01:13 PM
You set the charge current, then you can probably set a time limit such that it shuts off after around 90 minutes. Assuming you charge at 1C, this should give the charger enough time to completely charge a depleted battery (including the CV phase) yet offer some protection should it take too long.
BTW: I'm just guessing here as I don't have that charger.
03.03.2011, 01:41 PM
I just read the manual- you're welcome.
It assumes a 1c charge rate. Just set the amperage for 1c (5 amps for 5000mah)
There is no mah setting.
lucias
lucias's Avatar
03.03.2011, 01:44 PM
Thanks, I read it too but still kind of lost but that is nothing new
