rcBOB
03.05.2011, 12:49 PM
Thank you thzero, i tried the speed calculator but there is a problem :
the mph increase as i increase the number of teeth of the pinion (motor).
Is that a bug ??
And also i can't choose the different types of data because there's not a case in which it's written "Savage XL", there's just E-Savage, Savage Flux or Savage X but not Savage XL at all...
thzero
03.05.2011, 12:57 PM
Um, no. The more teeth you add to the pinion, the higher the gear ratio (numerically its lower), and the higher the gear ratio the faster you go.
Is that a bug ??
