Kirkinsb
Brushless All The Way!
Kirkinsb's Avatar
03.09.2011, 05:57 PM
You will LOVE the 1518 motor. it is all I run now. Gear higher and it runs stronger than the 1515 in any of my vehicles. Runs cooler and won't blow the rotor like a 1515 does when it gets hot. I have never blown a 1518 because they simply dont turn as many RPM. I have sure blown a couple 1515 rotors....That is my experience with the 1518.
togepipro
03.09.2011, 06:36 PM
OK, so a 1518 will be, + with the 1518 i don't have to cut the TVP's, only make the motor mounts bigger.
Thanks for all.
togepipro
03.10.2011, 08:15 PM
Thanks for all.
I buy a 1717 instead of the 1518...
What do you think guys will perform with these specs ?
Will get hot ?
The roll out pinion is 15. I'm going to use 18.
Differential Ratio: 3.2222222222222223
Transmission Ratio: 2.215277777777778
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 18
Total Voltage: 22.20
Motor KV: 1580
Tire Diameter (inches): 6.69
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.44 : 1
Total Ratio: 17.44873 : 1
Tire Circumference (inches): 21.02 inches (533.84 mm)
Rollout: 1.20:1
Total Motor Speed: 35076 RPM
Vehicle Speed: 40.01 mph (64.27 km/h)
Effective KV Value: 1580
KT constant: 0.86 oz-in/A
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
03.10.2011, 09:50 PM
The 1717 will run very nicely on 6s but the biggest problem will be getting it in the truck and getting a decent gear mesh ?
Heres what I did
Will need a RCM 3.3 Revo conversion motor mount and look here.
http://www.rc-monster.com/forum/showthread.php?t=28168
togepipro
03.11.2011, 12:24 AM
Heres what I did
Alza Racing sells a 49.50MM motor mount. I need to cut a little bit the rear of the right tvp. But I think is going to work. I put pics when Finish.
