Nixpus
03.23.2011, 11:54 AM
A little prototyping progress...
Cardboard TVPs with cut outs and batteries:
I need some sort of end stop on both sides of the dogbone. There must be a U profile with the right dimensions somewhere!
Servo can sit in its normal spot (more or less):
Battery placement in relation to the dogbone (vertically):
Ive got 1cm of 3mm thick alu on the bottom side of the TVP cut out at each end of the battery as it is. I wonder if its safe to go even lower? Damn I should have taken the 5mm TVPs!
If I could go lower it would help servo mounting... still for my friends inrunner project we need a different servo placement anyway. Bright ideas are welcome :)
ID:	9820   Click image for larger version
ID:	9824   Click image for larger version
Nixpus
03.23.2011, 12:01 PM
Because this is the stuff we need to fit into the construction:
The fat outrunner:
9 LiPo cells (its not the packs we'll use but you get the idea):
Its slightly crowded at the backend where I have CD and 1717:
We'll most likely have to do a cut out in the "bulkhead plate" otherwise the angle between the drive cups will be extreme... more fun challenges :)
ID:	9825   Click image for larger version
ID:	9826   Click image for larger version
