DrKnow65
DrKnow65's Avatar
03.26.2011, 12:18 PM
biddy, not a dumb question because you want to know :-)
The quick connect only works for the castle link. The castle link puts out voltage that triggers the quick connect to "switch", disconnecting the receiver and connecting the castle link.
The field programmer has no internal voltage supply to trigger the quick connect.
I'm not sure enough of the layout of the field link to know if it can be modified to have it's own voltage.
I'd say the two are incompatible until a castle rep chimes in.
