Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
molak
03.31.2011, 04:52 AM
Originally Posted by mistercrash View Post
Update on the LST diff modification. They are awsome, I disassembled the truck for some end of season maintenance and the diffs have no sign of leakage and run smooth as silk so I just cleaned the outside and put them back in the bulkheads. That's a whole spring/summer of racing and bashing on 4S with a few times having fun on 6S so they are very durable. An original idea from Lincpimp and I thank you for it.
I can't remember if I mentioned how I install them in the bulkheads now, I shave down some material on the aluminum cases of the diffs so that leaves the bulkheads intact except for a small portion that has to be Dremeled to accommodate for the front of the diffs where the two screws are. Here's a few pics, I hope they are self explanatory. This way of doing it coupled with the diff blocks really holds up to some serious abuse.
Based on your mods.
I took 1 step futher and did a machined version of the LST-revo diff mod... Removing the exact amount of material to fit and un modified Bulkhead (but the bolt part)
Here´s and album of it.
I hope you like it!
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
03.31.2011, 10:53 AM
That is one tight fit. Nice work on that molak.
No brain, no headaches.
Deahttub
03.31.2011, 04:11 PM
Molak,
Amazing work! My xxl diffs look nothing like those! I have a cpl extra cases...how much would you charge to machine them like you did??
Hey there...
bullseye0169
Hey there... - 04.07.2011, 04:35 PM
Originally Posted by molak View Post
Based on your mods.
I hope you like it!
Dude where did you get those brass inserts that you have used in the bulkhead???? I have a new bulkhead and found that some of the holes are striped right off the bat. I would really like to find those and put them in my truck... Thank you for your time...
