9920 and 9L connector
jvyango
9920 and 9L connector - 03.18.2006, 12:11 AM
Hi,
Im just a newbie and ordered a brushless combo from Mike. What will be the best connector to use to connect the 9920 and 9L? Would it be okay if a used bullet connector and what will be the size?
thanks ....
squeeforever
squeeforever's Avatar
03.18.2006, 12:38 AM
well the 5.5mm are certainly the best but i think that 3.5s are more widely used. thats what i use.
mmdooley
mmdooley's Avatar
03.18.2006, 12:40 AM
Hi and welcome, If you ordered a wanderer motor it will be prewired with 5.5mm bullet connectors. Mike has the extra connectors you will need. I would put these on both ends of the ESC and deans on the batteries. That's MHO.:027:
jvyango
03.18.2006, 12:48 AM
Its a Feigao 9L. I will used then the 3.5 mm bullet...
Thanks...
jvyango
03.18.2006, 12:49 AM
Another question.. What size of wire do you use for the 9920?
Sylvester
Sylvester's Avatar
03.18.2006, 08:25 AM
12 gauge wire.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
03.18.2006, 08:26 AM
IMO, only high quality 12awg wire, such as W.S. Deans wire, should go on these expensive components. It is really up to you, but 12awg(gauge) wire is the best.
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
coolhandcountry
coolhandcountry's Avatar
03.18.2006, 08:38 AM
I agree with brijar. If you go with cheap stuff it will not flex like it supposed to on a rc. You will break some strains in them and hinder you current.
Peace!
Country
Help support the
Rc-Monster
Buy here
