agarabaghi
04.13.2011, 04:51 PM
i have a hitech 7955 im looking to sell... pm me if u want it
Last edited by BrianG; 04.13.2011 at 04:57 PM. Reason: Please do not post selling prices per forum rules.
Sounds like
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Sounds like - 04.14.2011, 02:07 AM
Well there ya go. It sounds like it is time for "LETS MAKE A DEAL". Now you can get the right servo, and hopefully at a discounted price. I believe the 7955 sells for around $125 new. You can find them on the T/H site for $100 as a super saver member sometimes. Good luck.
SUPERMAXX YOUR LIFE.
04.14.2011, 06:47 AM
This might be a little off-topic, but what does it mean when a servo is labeled as cyclic? Does it mean they are constant rotation or something else? They seemed to be used in helis mostly.
Dose anyone have an inside man at Hitec or Futaba that they can post these questions to them for us. I mean I can understand that yes wheeled vehicles are under more pounding pressures than plains are, but how much different can these servos really be inside to make them special for one or the other? I am curious now as well.
servos are servos are servos. Cyclic just refers to moving swash plates on helis. It's no different than saying steering or throttle servo.
Air/land/sea/cosmos they are all the same and just renamed for a broader sales spectrum.
Good info from the chair.
JERRY2KONE
JERRY2KONE's Avatar
Good info from the chair. - 04.14.2011, 07:38 AM
Not sure what your references are Harold, but that is pretty much what I was thinking as well. i mean really, what could they possibly do to one servo from another that would make it propriatary to only one R/C field and not another? Metal gears are metal gears, right? Seems to me that all of the specs depend on what you plan to use it for, and how much you are willing to pay for it.
The only other question still looming is why would a servo have a spec that says nmh batteries only? I don't really see what difference it would make where the stored energy comes from as long as the voltage is within the specs of the servo requirements, right? After all we are not talking about rocket science here. The only real issue is whether you purchase the right size servo for your application, and also that you get a servo strong enough to hold up to your pounding on it. Case solved Professor Paralyzed.
