Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Manne
04.21.2011, 02:20 PM
Super small update:
I have a troublesome heat source in my truck......
Iīm using 4s 25C 7400mah rhino lipos.
First I was geared very low, 36.22 mph (58.18 km/h)@3.7V per cell, and with that gearing the temps were fine but the truck was just silly slow.. So I regeared from 65/21 0.8mod To 47/17 Mod1.
From that Iīm getting 40.55 mph (65.13 km/h)@3.7V per cell That is totally okay with me but the temps are trough the roof.... I donīt know If I cooked the 2350... It cogged like crazy in the end of the run, only from a complete standing tho so I donīt know what was wrong... I could run it in super slow "crawling" speed but it was as I said very coggy from a complete stand still...
I will try with my Neu/castle 2200Kv and see if the motor is dead, add a CC blower or just a computer fan and then we will then see If I need a 1520.....
thzero
04.21.2011, 02:30 PM
I've been running mine with the 2200kv and its been pretty good on 2S 30C 5000mah batteries. Geared 47/20 with bulletproof diffs, flux tranny, and ProLine 3.8" Trenchers.
scarletboa
scarletboa's Avatar
04.21.2011, 03:00 PM
Originally Posted by Manne View Post
Super small update:
it sounds to me like you cooked the motor unfortunately. i think either that 1515 1y 2200kv motor should work fine or maybe a 1518.
love the build! i am currently scavenging ebay right now to get some parts that i need thanks to a screw-up on my part. i tried to add some jb weld to the 14mm hexes in some of my older tires' hexes and mounted them with the non-dry jb weld in an attempt to get a tighter fit between the hex and the wheel. it worked for a little while until i broke a knuckle and realized that i had effectively jb welded the hex to the axle. now, i already have the new knuckles and am looking for cheap axles. i am also looking for new dogbones because those are worn out and need to be replaced anyway.
Manne
04.23.2011, 12:14 PM
scarletboa:
Yeah I thought so too but it was fine I have now sucessfully driven the truck four packs since the Heat incident. The motor is just too small, Iīll try the 2200kv but I doubt it will handle my driving any better in the sandpit..
Iīll figure it out.
Now I have another problem I keep bending the motor mount plate forward ( so the gearmesh gets to tight ) when I do my 17feet high nosedives So I will try to moke up some kind of brace, I think Iīll need atleast a 5mm thick motorplate to not bend it... It feels easier to just make a brace
The motormount have flexed so much that my pinion rubbed my recieverbox Thas is ALOT of flexing Iīll post pics later on
Also, I think Iīll go with rpm a-arms for the front and stock for the rear, Since Iīm only bending dogbones in the rear. Or maybe Iīll try rpm all around and see if the dogbone situation gets worse, Itīs totally okay as it is right now, they only bends slightliy in the rear, nothing to be worried about.
Iīm actually amazed that they arenīt bent more since the dogbones are almost bottoming out in the diffcups/outputs due to the bad machining of my Integy hubs.....And I have catched Major air and landed perfect for bending dogbones countless times.
Soo far, GREAT truck, It has already taken twice the beating that my revo build ever managed to take.
