Go Back   RC-Monster Forums > Support Forums > Team Tekin
freddy
04.22.2011, 03:28 PM
Originally Posted by TekinTeamMgr View Post
I don't recommend giant mah batteries though.
Let's get one thing straight. If a battery is only so large, you can either get punch and voltage, or you can get runtime and less punch.
Lipo batteries are simply electric gas tanks. You can either get a lot of power and less runtime, or less power and a lot of runtime. Take your pick.
not true im afraid
these batterys isent following any specefic size regulation so the larger capacity ones is also larger in size
the 6000 can deliver more power and amps than the the equal 5000 ones, it also have less resistance..
The turnigy nane tech is great, i have a bounch of lipos including hyperion and i can say the nanos have alot of power.
That a esc fail isent that uncommen for many reason but blaming somthing else is just not necesarry, it could have been many things like snow, water, wiring, connector, servo, heat, soldering ore perhaps even the esc failed becouse of years of stress ore faulty components.
