Prismatic cells look nice.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Prismatic cells look nice. - 04.26.2011, 09:25 AM
Thanks again Snell for the info. I was thinking about those prismatic cells as well, but I am not seeing the voltage on them? At $51 a pop how many would one have to acqure for the (48VOLT, 1000 WATT HUB system? Just trying to get a good picture as to what getting my bike setup for this. I also much rather prefer the split/twist throttle because it is more like a motorbike, which I am used to. All of the info is great and the pricing is pretty good as well. Escept that is for batteries when you add everything up. Cells can run you quite a bit, and acquiring a custom pack would be even more so. No matter how you do this your looking at pretty much $1000 to $1600 for a good setup that will move you around easily even up hill, and cover a fare amount of milage on one charge. Hell one could easily run back and forth to the local market and fill up on food without breaking a sweat.
SUPERMAXX YOUR LIFE.
