Rear diff.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Rear diff. - 05.02.2011, 04:51 PM
Sounds like a rear diff issue. The only way to find out is open it up and inspect it. With the front wheels on the ground, lift up the rear and see if you can spin both rear wheels in the same direction. If so does the rear driveshaft spin, or not? That will tell you if it is the rear diff, or the tranny or center diff depending on what your setup is.
SUPERMAXX YOUR LIFE.
