thzero
05.03.2011, 12:45 PM
Does the XL use the same transmission as the Savage X? If so, did you lock it in 2nd gear or are you using the 2 speed?
Easiest thing to do would be to enter your data in the top speed calculator, use the "export values" button, then copy/paste the information here. You could be simply overlooking something...
Sounds like he replaced the gearbox with a Losi center diff.
