Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
crusey_aus
05.15.2011, 03:39 AM
Hello Folks,
Just did some testing of the Tenshock 6 pole motor X802 (2400kv)
Car Setup
Slash 4x4
Geared 21/52
Proline Streetfighter Tires (4.5" diam)
Trackstar 150 ESC
0% Punch
3s 6000mah 25c Turnigy Nanotech
Ambient Temp 55f
Theoretical Speed (scriptasylum calc) - 51 mph
Recorded data from an Eagletree v4
1st run
No motor timing
Temps after 10 minutes of high speed runs
Motor 120f
ESC 85f
Peak Amps - 177.5
Peak Watts - 1780
Min Voltage - 9.98
GPS Speed - 54.4 mph
2nd run
Added 16 degrees of timing
Motor 150f
ESC 95f
Peak Amps - 175
Peak Watts - 1801
Min Voltage - 9.98
GPS Speed - 55.5 mph
Not sure what to make of the fact that adding timing appeared to change nothing except raise the temps, was suggested that these motors come alive when its added
Not bad results though, quite happy with the motor, will push it a little harder and do some 4s testing soon
Cheers
