Candyman2
Candyman2's Avatar
05.15.2011, 01:33 PM
not sure yet, its fast on the grass, im on a 17 pinion, im going to push up to 19/20 and then get you guys a video :)
Candyman2
Candyman2's Avatar
08.06.2011, 08:50 AM
Making a new chassis, going to put the motor at the front to tame the wheelies.
Standing the lipo up so I can have straight prop shafts, 10mm longer than before, dimensions are more or less that of a Rustler.
milled some areas to loose some weight.
put the servo flat as there is room now. Just need to make prop shafts up.
