05.18.2011, 02:14 PM
They will be coming back soon...
Not positive about the 1717 tho. We do have replacement rotors for the 1717 on the way.
A 1720 motor with lower kv would be the hot ticket. Nice to offer that with the mamba xl as a combo.
BIG-block
05.20.2011, 02:16 AM
Amen. That would be a perfect set up for light 1/5th trucks or obese 1/8th ones. I honestly can't believe that the motors they cleared out were selling so poorly. I love every one of them. 1518 in my buggy, 1520 in my truggy and I haven't used the 1717 yet but I have seen what they can do. It will be going into a Savage eventually.
Anyway how bad do you guys think it will be to run the 1717 on 8S? I know that puts it @ 53,000rpm but with some voltage drop and load on the motor would it be possible for it to hold together for a few runs. I guess I could try 7S but would prefer to give 8S a crack.
Unsullied_Spy
Unsullied_Spy's Avatar
05.20.2011, 10:27 PM
Watch temps and don't push it to it's max speed and it should be an absolute animal. Patrick said a while back that they're rated to 45,000 RPM because the magnets will start coming apart at higher speeds. I've run this motor on 4s and 6s and it's stupidly powerful in a very heavy 1/8th scale Truggy, 8s would push a 5th scale pretty well if you were smart about your setup and watch temps. Main problem I see with running it on 8s is accidentally over-revving it, I'd stick to 7s max myself.
BIG-block
05.21.2011, 11:17 AM
Hmmmmm, I think you are right about 7S but I want to fit this setup to a Savage flux and fit one 4S batt on both sides. Going to 7S might cause bit of a imbalance. That is the main reason why I wanted to go with 8S. Wouldn't be nice if the MMXL had a rpm limiter. You just dial into the CC Link what your motors safe rmp is and presto, can't over rev it.
Being a such a over powered rig it will be doing a lot of back flips and spending a lot of time in the air with a fair bit of throttle input for flipping and correcting during flight. This is where I see the over reving becoming an issue. I would hate to destroy one of these motors before Castle starts to make something similar again.
sikeston34m
sikeston34m's Avatar
05.21.2011, 11:27 AM
Why couldn't you limit the throttle to about 90% in the ESC setup?
What you will find is going to be an insanely overpowered beast anyway.
BIG-block
05.21.2011, 12:51 PM
It always amazes me how I manage to overlook the most simple of things or just over complicate. Limiting throttle is a brilliant idea. I do remember BrianG saying somewhere that limiting throttle EPA to slow down your car isn't a good idea. What would be the difference between doing that (setting the throttle EPA to say 85-90%) and just not using the full throttle? I know what he said has to do with the FETs having the easiest time when they are operating at full throttle but not exactly sure about this.
ta_man
05.21.2011, 03:13 PM
Limiting throttle doesn't have as much effect on peak RPMs, especially unloaded RPMs, as you might expect.
Quite some time ago I did some tests where I gradually turned down my throttle endpoint and measured the top speed of the car at each step. At 70% throttle, I was still at 90+% of top speed.
I was doing this to test the effect of "throttle driving" (a racer term few bashers would understand or comprehend) in a spec class with limited battery. Knowing how to do this got me many wins because I always had battery left over at the end of the race when others were on the verge of dumping because they were pulling full throttle down the straights all the time.
This was a long time ago, but the principle still applies.
Remember, if you turn your EPA down 10%, the ESC is applying full power 90% of the time and you are coasting the other 10% (admittedly in very small increments). But that 100% power, even if only for 90% of the time, is going to get you pretty close to the top speed at 100% EPA.
RC toy
Got Brushes? NOT
RC toy's Avatar
09.07.2011, 01:26 PM
So when new CC link version is going out, Patrick?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.20.2011, 11:42 AM
This would be a beast and sell very well IMO, The 2028 is just too much for most apps.
