Ferret
05.22.2011, 01:11 PM
I "revived" laptop batteries by starting to charge them with the NiMh of the chrger and after the voltage rose a little bit switching to LiIo mode.
pinkpanda3310
pinkpanda3310's Avatar
05.22.2011, 07:03 PM
If cheap and nasty is your thing... you cuold try going to tool repair shop's and ask for disfunctional Makita Lion battery packs. They are 18650's with 1500mah. Just check each cell before using.
whitrzac
Can't catch this...
whitrzac's Avatar
05.22.2011, 08:00 PM
I'll have to open the batt when I get it to see what cells it uses...
I know your not "supposed" to use lipos, but would there be any harm in useing something like a 4s pack?
this is the batt I'm talking about... $90 is the cheapest I've seen new batts...
http://cgi.ebay.com/NEW-Alienware-M1...item2c5bc0c2ff
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
05.23.2011, 03:12 AM
Not tons better, but how about $75 for a new one?
http://cgi.ebay.com/New-Battery-Akku...item3f032b174e
Not sure if that's what you're looking for or not, but it seems to have the same part number. Only problem is it's from China, so will probably take forever to get there.
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
whitrzac
Can't catch this...
whitrzac's Avatar
05.23.2011, 11:15 AM
whitrzac
Can't catch this...
whitrzac's Avatar
05.24.2011, 01:55 PM
anyone use these??
http://cgi.ebay.com/UltraFire-18650-...item43a70ab9f4
http://cgi.ebay.com/2x-18650-3000mAh...item3cb8204b48
http://cgi.ebay.com/1X-3800mAh-Ultra...item3f0a118a87
brian015
brian015's Avatar
05.24.2011, 02:09 PM
Someone actually decided to name their batteries "UltraFire"???
Suggested slogan: "Our cheap eBay cells burst into flames waaaay before the competition"
But I have no idea - they could be very good.
sikeston34m
sikeston34m's Avatar
05.24.2011, 05:41 PM
Caution! Beware!
Ultrafire 3000mah are being counterfeited. Old Cells are being rewrapped and scammed. I have received samples of this cell that ONLY produced 200mah.
I'm skeptical of the others also.
The highest verified mah of ANY 18650 cell that I have tested is 2600mah.
If you see ads that boast 3600mah or 4000mah 18650's, Maxamps should be selling those! They are fake ratings.
If you want reliable numbers, you have to stick with the trusted name brands.
Sony
Sanyo
Panasonic
Samsung...........Just to name a few.
J57ltr
05.27.2011, 12:37 PM
While you can do this (and I have) they typically will not hold a charge, and if they do they will not put out even half their capacity. Like sikeston said when they are dead they are dead.
Oh, and good luck getting them to stay in balance.
Jeff
