Hot bodies 1/8 diffs -
06.17.2011, 01:13 PM
I bought flm hybrid bulks and almost have all the parts.I just need 1 more hbsc 8028 43t bevel gear and I can put them together. Does anyone know where I can find one? It seems that no has it in stock. If someone has one for sale I would buy it.
thanks,
Mike.
06.17.2011, 11:03 PM
Thanks for taking the time to respond. I found a place here in the states called Discount RC. It shows that they are in stock. Does anyone have experience with them?
http://www.discountrcstore.com/Hot_B...p/hbsc8028.htm
06.20.2011, 06:21 AM
I just got notice of a refund from Discount RC. I found another place. suicideneil have you heard of, or had any experience with this store http://rc4speed.com/index.php?route=...roduct_id=129?
Thanks,
Mike.
06.21.2011, 06:26 AM
Never heard of them, but if it's a European website thats probably why ( I mainly come across English, American or Chinese sites )- they take paypal and creditcard so you should be perfectly safe if they dont deliver the goods. :)
06.23.2011, 12:07 AM
I'm putting together one of my hybrid bulks, and I am trying to get the right number of shims. Is it normal to hear any noise from the gears? or should it be completely silent? I am using gorilla snawt on the ring and pinion. I tried it with 2 shims and had some noise. I tried it with 3 shims with more noise. No shims about the same amount of noise. 1 shim seems to be the best, but i can't get it completely silent.
06.23.2011, 01:52 AM
It's not noise you should be looking for really, its much more about feel & smoothness.
Ideally the pinion gear shouldnt be able to move in or out more than a fraction- it shouldnt bind however as you rotate it / the ring gear once assembled. Likewise, the ring gear / output shafts shouldnt be able to move in or out ( side to side ) more than a fraction.
Every diff is different due to maching tolerances but a few 0.2mm shims hear and there should do the trick; so long as the diff roates smoothly and doesnt bind or have excessive play, you'll be fine :)
06.23.2011, 06:20 AM
I have little to no play at all in the output shaft so I think I'm O.K.
Thanks again,
Mike.
06.24.2011, 11:02 AM
Are you using the hybrids on FLM's extended chasis? If so, how well does your front drive shaft connect to the break?
06.24.2011, 11:41 AM
I will be using my hybrids on FLM's extended chassis, but I don't have all my parts. I am awaiting the arivial of my ring gear from some where out of Europe. The main part that I am waiting for is the universal CD/engine mount. I recieved word that Mike is tweaking the mount and they should be ready soon. As soon as I get those parts I can complete my build. So for now I can't answer your question, but I hope I will be able soon. I will post pics of the build process here when I can.
06.24.2011, 06:37 PM
The new CD/motor mount is now up for sale. I have one on the way. I hoping that the ring gear will come in the next few days. It is marked as shipped but it is coming from
Malta of all places so I don't know how long it will take to ship.
06.24.2011, 11:26 PM
Do you guys have any idea what size shims I should use to stop the little bit of side to side movement of the diffs?
06.24.2011, 11:30 PM
06.25.2011, 12:10 AM
So the same shims that I used for the pinion gear.
06.26.2011, 10:25 AM
what are the part numbers for the spider 1/8 diffs (ring, pinion, etc....)? If I break the HB's then I will go to the spiders.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
