08.05.2011, 07:18 PM
The aluminum rod I used for the towers wasn't the best quality stuff and was definitely weaker than the New Era towers I had. But good looking out and I really like your nylon rod idea anyway. Easy to work with, no worries that it'll bend or break towers and it should be alot cheaper in the long run compared to buying posts made for a stock truck.
Yeah, you can buy a meter / yard of nylon rod ( Delrin usually ) for a couple bucks which is enough to make a dozen or more posts, compared to one set of posts which costs ~$5 or so. Seen it done a few times over the years and it works & looks fine + very cheap ofcourse.
cmac
cmac's Avatar
08.06.2011, 01:01 AM
Ok I don't have the hinge pins, but I made my second ESC plate. This is just a trial fit I will have to file and sand and then send all the parts to be anodized.
ID:	10100   Click image for larger version
ID:	10101   Click image for larger version
cmac
cmac's Avatar
08.06.2011, 01:03 AM
More.....
ID:	10104   Click image for larger version
ID:	10105   Click image for larger version
cmac
cmac's Avatar
08.06.2011, 01:04 AM
Even more.....
ID:	10108   Click image for larger version
ID:	10109   Click image for larger version
dtnel
08.06.2011, 03:51 AM
Originally Posted by cmac View Post
Even more.....
How did you get a red flm chassis by chance or is that not a flm chassis as it appears that it looks like what I have ???
