_dV
08.06.2011, 09:57 AM
How is truck doing now? Made any more changes?
Nixpus
06.08.2012, 09:45 AM
Truth be told I crashed it last fall and didn't feel like disassembling it again... sooo its been sitting in the basement until recently.
Lately I found the urge to fiddle with it again so its been updated a bit more:
Strap me up Scotty!
Its almost a G-Savage :)
Center diff is locked 100% This means that instead of unloading the front wheels I unload on all 4
It doesnt wheelie well, doesnt flip over well... its no longer a Savage - its something else.
ID:	10368   Click image for larger version
ID:	10369   Click image for larger version
Bmr4life
06.08.2012, 10:39 AM
Thanks for the update. What's the benefit of converting to a CD if you lock it up? Does it change your gearing options also?
_dV
Arrow 06.08.2012, 05:29 PM
Nixpus: Nice work on the straps though I hope they don't get too beaten up underneath.
With the locked center diff it should wheelie great. What do you think might be the problem?
Bmr4life: Benefits of converting to a Center Diff
- gives you flexibilty to change the internal layout of the Savage, usually for the better
- gets away from the troublesome stock slipper and it's mount
- simplifies the center gearing so less potential issues there
- less gearing friction loss
- less weight than a center gearbox
- depending on the individual build it can make the Savage much much easier to work on (my CD drops straight out the bottom with a few screws)
I don't particulary agree on completely locking a CD though I have never tried it myself. I run Ofna diff lock fluid so that I have a at least some end to end shock dissipation. It will be interesting to see how Nixpus's driveline stands up to a locked CD.
Gearing options usually turn out to be similar depending on what spurs are available\fit. Mine is geared close to what the stock gearbox gives.
Bmr4life
06.09.2012, 02:47 PM
Thanks for that response. I've been mainly looking into a CD to remove the wheelies and help with flipping during turns.
