bruce750i
bruce750i's Avatar
08.18.2011, 12:54 PM
Whats the stock motor size, kv and wattage? 28x50mm? 4000kv? 300-600watts? or do those come brushed? Mounting hole width?
Tenbol motor mount maybe needed?
Maybe like a 400-450 sized outrunner, kv depends on what voltage and speed range you want.
speedy
08.18.2011, 04:45 PM
The stock motor is an inrunner 2 pole 4000kv 28x48mm and rhe wattage are about 400-500w on 3s lipo.
But i have a mm- pro esc for it noe so i kan run up to 6 s with a nother lower kv motor. I whant it to go about35-40mph!
