Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
FG101C
09.12.2011, 02:20 PM
Got into my diff and it's actually fine, what broke was the right side outdrive cup at the pin. Since I'm using flm XL bulks I need the specific outdrive, not the ones that come with the diff. I'm using the super hd outdrive but had to assemble the diff in the bulk, lol, hope another one dosent break.
FG101C
05.08.2012, 03:42 PM
Has anybody else used this setup from Fastlane? http://www.fastlanemachine.net/prodd...iew=all&cat=22
My question is about the outdrives pictured, what else works? The Heavy duty Flux outdrives wont work because of the way the bulks go together, the holes are too small for the Flux HD outdrives. It appears the one's pictured are the only one's that will work, the problem is they break where the little pin goes in to drive the sun gears.
Is there an alternative?
Thanks.
mothman
05.08.2012, 07:20 PM
I guess your only option is to buy the outdrive from FLM. Dont see any other option since the ball size of the dogbone is 11mm..
Thanks.
