Savage flux xl build
freddy
Savage flux xl build - 09.21.2011, 12:18 PM
Did a complete strip down and changed any worn parts, its a durable truck so it was only some drive cups and broken pins that need to be replaced.
But now to the fun part also changed the chassie plates to Alza racing xl 4mm and upgraded the motor to an 1717, to finish it off i also mounted the high speed idle gear and an longer motor plate.
What i like about these chassie plates is that you have two mounting options for the battery boxes, so you can somewhat tweak the weight distribution.
The body is torn to pieces so really nothing to show.
