cmac
cmac's Avatar
09.25.2011, 12:28 PM
I got to take it out and I'm having a problem with the truck pulling to the left. I have the wheels pointing dead straight. It seems that the servos don't want to center. They will center when I give the wheel a quick turn left or right a few times. That is fine when sitting still, but if I have to do that when the truck is up to speed that will = a crash!!!! I guess I'm going to have to wait till the Hitec 9380's are released:(. I will tell you guys it sounds really cool when running, much different than the stock brushless. It will pull the wheels off the ground at will. Even though it has all metal gears it is not as loud as my stock truck. I'm just afraid to bring this thing up to speed if it's going to act all squirley. Yes I did center the servos when mounting the steering linkage. I don't have another set of servos that I could use, and I don't want to buy something that I won't end up using later.If I adjust the trim when the servos truly center they will pull the side so I don't think that would be the solution. The servos are Hitec HS 5625's. Any thoughts guys?
Amazng
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Amazng - 09.25.2011, 04:43 PM
Your truck looks amazing. You did a great job and you have somethng to be proud of for sure. The issue you are having seems to be pretty common and I am sure that most of us have run into this issue at one time or another. How about trying to use just one servo and then the other to see if it is one servo or both that are giving you the problem. Are you using a BEC, or just running both servos off of the ESC? Running two servos on the ESC might just be too much servo draw to deal with. Especially if they are high torque servos. I have had servo issues myself and still do not quite get how different some servos are when all the specs seem to be the same. The other thing that I believe you are going to have a problems with is using aluminum rims under power. Super-glue just does not stick too well to aluminum, and they will seperate fairly easy under load. There are several threads inhere about using beadlock rims, balancing wheels, and also taping the tires to prevent balooning whih yu will more than likely see if you use a good range of power, torque, and speed.
SUPERMAXX YOUR LIFE.
cmac
cmac's Avatar
09.25.2011, 05:02 PM
Jerry, I have tapped the tires. I'm hoping that they wont separate. I took extra time to sand the wheels and clean the release agent from the wheels. No I'm not using a separate BEC, but these servo's are not super high torque. I'm hopping the Hitec 9380 brushless servos with the low power draw will fix the problem of using high torque servos without a separate BEC. As for balancing I found a solution for my Dynamite wheel balancer.
Dynamite makes an 12mm axle, and I just bought a 12mm to 14mm adapter so I will be able to use the Dynamite balancer with these 14mm wheels. Balancing all my 17mm wheels has made such a dramatic difference in how my other truck ran I will not drive a truck/car without having the wheels balanced. I'm hoping all the extra time and care that I took gluing the tires on will result in no tire blow outs. Only time will tell. I was not planning on any real high speed runs until I balanced the tires. Just like everything else I have done with this build I will take my time and think things through before proceeding on. Thanks for the advice, input, and kind words.
Mike.
