rawfuls
roofles.
rawfuls's Avatar
10.11.2011, 10:13 PM
Originally Posted by whitrzac View Post
all of the laptop screens I've come across have the same connection on the back of them...
Were you working on a specific line/model?
I've come across several with different connections from mobo ribbon cable, to LCD connections..
whitrzac
Can't catch this...
whitrzac's Avatar
10.11.2011, 10:17 PM
a few dells, a few alienware's(pre dell), an old HP 14, a older gateway... etc...
I know ribbon cables change from brand to brand, but I thought the conector on the LCD itself was universal.
rawfuls
roofles.
rawfuls's Avatar
10.11.2011, 10:18 PM
Have you ever compared them with the same cable?
They all look suspiciously the same, but they aren't.. They vary from size. # of pins, shapes, etc, etc..
whitrzac
Can't catch this...
whitrzac's Avatar
10.11.2011, 11:19 PM
I know they all worked on my gateway POS, I use it as a 'testbed' for laptop repairs.
I'm using a 7 year old(man date is jan 2004) WUXGA screen from a dell 9100xps in my 2009 sager np8660/m860tu.
I believe you, but I haven't come across a screen that wasn't compatible with the cable I was using
Found the solution
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Found the solution - 10.12.2011, 02:15 PM
I found the solution to your problem Thiessen. Watch this video tutorial and you will be back in business before you know it. This is one of the best reasons to buy a Macbook as you will ever see. Enjoy.
http://www.youtube.com/user/gradualr...26/NCybRFMW7-M
SUPERMAXX YOUR LIFE.
