brian015
brian015's Avatar
11.25.2011, 12:14 PM
Originally Posted by brian015 View Post
I got the cm26 6800 installed with a 12t pinion and 65mm on road tires. So the top speed should be the same as stock. I'll try it out when my parking lot dries out and report back.
I had a chance to test this today and it was very fast, yet controllable with the 12t pinion. I have a 1/10 sidewinder running the cm2668 so it should have no problems. When I get a chance to run a full pack through it I'll report back on temps. But I'd say this is a great setup for running on-road tires.
Unfortunately it looks like CC recently sold out of the cm2668 motor (I was thinking of buying a back-up)
Edit: I guess, looking at the numbers (and available pinions for the 1/8" shaft), my second choice right now to run this on-road would be the cm2646 on 3s - it should perform about the same as the cm2668 on 2s.
