RC-NUT
RC-NUT's Avatar
11.27.2011, 10:08 PM
The LST2 shafts are the same length for the front and rear. It would have been sweet if they fit.
This is going to be a standard length build.
Design #2 is under way. I've flipped the motor 180 deg so it's now in the front of the truck. I think that will be better for weight distribution. I'm also working on a new bracket layout. The heavy duty Flux CVD will be in the rear and a 110mm dogbone will be in the front.
