You can sleep in a car, but you can't race a house
01.09.2012, 09:43 PM
Originally Posted by brian015
In my case, it was the motor mount itself that was misaligned, not the motor to the mount - if that makes sense.
I don't think that will be the case for me then. I'm using the factory drilled differential holes. All I did was switch the direction of the diff. So it should be fine.
