snellemin
2 KiloWatt RACER
snellemin's Avatar
01.17.2012, 11:18 AM
Disabling the BEC does decrease temps. But that is with ESC's that have Linear bec built in. Switching becs are more efficient thus less heat. I've been using Dimension engineering BECs on my smaller ESC, just so I can run higher voltages in my old dragracing days.
Using a external bec with the MMM is useless and won't gain you anything. Only time the BEC is used, is during steering and braking if a mechanical brake system is used. Braking is at the finished line and steering is at a minimum.
The extreme drag racers, go as far as removing the heatsink on the MMM. But never add a external BEC. That is just unnecessary weight.
With the Dimension Engineering BEC there is no need to cut/remove the red wire.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
RC toy
Got Brushes? NOT
RC toy's Avatar
01.17.2012, 04:16 PM
But what if I run one high torque, three micro servos and maybe even a 3W led on my bec? I don't think MMM would supply enough amps to feed all this...
Btw, is switching bec still only around 80% efficient?
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.17.2012, 04:48 PM
I was referring to drag racing. Bashing and racing is a different situation and Castle offers two external becs for those that need them.
TexasSP
Something, anything, nothing
TexasSP's Avatar
01.18.2012, 11:17 AM
If you are running that much, you might want to go with the pro version. Probably not completely necessary but worth it for the added assurance.
www.cubicle101.com
