ANGRY-ALIEN
ANGRY-ALIEN's Avatar
01.23.2012, 04:54 PM
Simple shapes are cut easily with a cutoff wheel and finished with sandpaper... so, you shouldn't have much of challenge Thirdgen...
I am not sure if the options below are cheap, but I am considering them...
2.6mm - http://www.ebay.com/itm/Carbon-Fiber...item19cc68fdc4
4.4mm - http://www.ebay.com/itm/Carbon-Fiber...item1c22878760
3.5mm - http://www.ebay.com/itm/Carbon-Fiber...item1c22878728
Alien
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
01.23.2012, 07:49 PM
Alien
The 3.5mm one would be GREAT for a chassis build. 12" by 24" is definitely big enough to machine a chassis in its entirety.
I ended up buying a smaller section last night in 2mm. Its not thick enough to be a structural part, but it should be rigid enough with support to be a ESC or Radio Tray. Was also only $17 shipped.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
Thirdgen89GTA
01.30.2012, 01:56 PM
Finally arrived. Took a while to ship from the UK, there is definitely PLENTY of material here to make my center diff brace extensions to the front/rear of the truck. And its exceedingly rigid. I don't want to test its flexibility yet. Hopefully with the strut mounts I add below it won't have the opportunity as i imagine it would crack. Thankfully I'm not using it in that fashion.
Looks like they sent me a 3mm version I think. I'll have to measure it at home with the calipers.
