BIG-block
01.27.2012, 02:16 AM
The input cap is probably to help cope with ripple currents. The motor/ESC is generating the ripple, but it is also present on the BEC wires as well. Couple that with the longish BEC input wires may cause undesired BEC operation in the switching circuit.
Cool. Thanks for that Brian. I kind of figured that input voltage being so much higher than whats going out isn't going to be troubled too much by ripple currents but I can see what you are saying. The jest of it is it just gives the BEC a smoother voltage to work with. Right?
Anyway both versions work just fine in my applications. They are mainly all powering just a steering servo except one that is also powering 8 LED's as well. 4 of the older ones and 2 new version seem to work just fine.
Early on I was warned about using CC BEC. I was told to use Dimensions Engineering BEC instead because the CC switching BEC could possibly send full battery voltage to my servo/Rx in case of a failure. Well two years later they are all kicking butt. Also considering they are only $20 and so easy to adjust voltage output I will not use anything else. I will have to get the Pro version soon because for my XL. Hopefully it will also be trouble free as the smaller ones.
