brian015
brian015's Avatar
02.02.2012, 09:11 AM
Originally Posted by magicald View Post
Yeah, forgot to include that I'm using huge wheels and tires - 55 series Cen snipers...this is probably really screwing up my gearing. They really are not much heavier than stock muggy.
I'll have to do a run with my stock wheels.
Part of your problem may be that you are geared for almost 70mph, if my calculations are correct:
Differential Ratio: 4.090909090909091
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 17
Total Voltage: 22.20
Motor KV: 1580
Tire Diameter (inches): 7.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.82 : 1
Total Ratio: 11.5508 : 1
Tire Circumference (inches): 23.56 inches (598.47 mm)
Rollout: 2.04:1
Total Motor Speed: 35076 RPM
Vehicle Speed: 67.76 mph (108.84 km/h)
Effective KV Value: 1580
KT constant: 0.86 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
