rcs2022
02.15.2012, 01:21 PM
I'm really liking the project, myself am still in the middle of something similar.
If you don't like wheelies and want more planted stance, definitely go with motor in front flipped backwards, thats what i did, and it drives really great! still need to update a video in my build.
What esc are you planning on using?
If you are going for mechanical brakes, the motor heatsink you modeled can be thicker to clear the brakes, then you won't be worrying about strength.
planning on machining it yourself or getting it done in a machine / cnc shop?
RC-NUT
RC-NUT's Avatar
02.15.2012, 05:31 PM
Thanks man. I'm not planning on using mechanical brakes. My last Savage build had a problem with the brakes being too strong on the 1717. If I tapped the brakes the truck would do a violent front flip. I had to program it out on the MMM. I will use the same ESC again with the 1520.
I plan on machining some it it myself and farming the rest out. I have a bridgeport at work but I'm not the greatest.
I hope with this design, and some programming, I can get on it and the truck just takes off. Before, anything over 1/2 throttle and I was on my lid.
