Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
02.17.2012, 12:27 AM
You'd have to find out what grade titanium it is.
It seems like Grade 5 is the most commonly found. Which just happens to be the same stuff in the link you posted.
http://en.wikipedia.org/wiki/Titanium_alloy
As for the quality of it, I don't know. I'm not as up on titanium grades as I am on Aluminum.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
Aussie Nerd
02.17.2012, 02:01 AM
Grade 5 (6al-4v) is the good stuff, so for that your choice of material is fine. 2.54mm is not much thinner than the 3mm you have currently so I'd say it should be fine. For bending Ti, I just cold bend it. Be careful though, it generally has a lot of spring back, so just take it a little at a time until you have the desired angle. Grabbing it in a vice and bending by hand (and perhaps with a little persuasion from a soft hammer) should suffice.
Best part is if you bottom out on abrasive surface you should get some nice pretty sparks
Cheers
Kieren
Thirdgen89GTA
02.17.2012, 09:47 AM
Cheers
Kieren
Yeah, I want a Ti skid plate for my big on-road car to protect the chassis, but most importantly i want cool sparks at the track when it hits the ground.
