Thread Tools Rating: Thread Rating: 17 votes, 4.53 average. Display Modes
02.17.2012, 10:28 PM
Originally Posted by FLoJo View Post
...think they block my ip cuz the website wont load up either lmao o well
The site's been giving me problems loading too and I'm not banned or anything.
But, if they are blocking your IP:
If you are using a cable/DSL modem and your ISP is using DHCP, try disconnecting power to the modem overnight or longer. When you power it back up, it will hopefully be assigned a different IP from the ISP. If you don't leave it off long enough, it might simply be re-assigned the same IP. Same thing if you log into your router's web interface and just release/renew the WAN IP.
Again, this only works if they assign IPs by DHCP. If they assign your modem a static IP, then you're out of luck unless you want to call your ISP and see if they will assign you a different IP (and they'll probably want a good reason why).
By the way, none of all that above will cause any issues with your internet, although you may have to run "ipconfig /flushdns", but unlikely.
