RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.29.2012, 03:37 PM
Originally Posted by Jony Nitro View Post
I have all the above electrics
14s do weigh heavier, thats why i was asking about saddle aswell
Jon
Then it isn't a theory now, is it? Does the ESC have car firmware and brakes? If not, you would need another servo, servo mount, etc. as well. Without good car firmware, startup leaves a bit to be desired as well. The mount is only one hole away from accepting mechanical brakes, and the stock brake disc will work with the 2028 motor and an 18t pinion or larger(could also trim the disc to allow smaller pinions). The setup shown here is ideal and will work for most without any additonal complexities. For your 14s setup, you may need to do something differently - I guess you maybe already knew that, though(14s in itself is out of the ordinary - I have a 1:1 electric dirt bike that runs on 14s so maybe it is a little overkill for this car?!). :)
