Thread Tools Rating: Thread Rating: 44 votes, 5.00 average. Display Modes
04.03.2012, 03:09 PM
I think that mounting your motor mount sideways (like in post 16) is the way to go.
Make two plates that attach to the chassis rails with existing holes, drop the diff in to measure the spacers you need then attach the diff to the plates. That would get it low enough and straighten out the axles.
IrishChamp
04.04.2012, 01:14 PM
I've strongly considered that, maybe I should revisit the idea, I do think however that I will need to get a new mount as this one is presenting more and more little issues. I just noticed that the motor won't sit flush against the mount because it has a small raised area around the shaft bearing that does not fit into the center slot of the mount.
I've beep looking around locally and online to try and find someone who is willing to make a simple custom mount for a reasonable price, something that attaches to both sides of the chassis and does not need a mounting plate
