starscream
RC-Monster TQ
starscream's Avatar
04.01.2006, 03:19 PM
I forgot to mention my dilema,
I have a 1/8th center diff for the Revo tranny but the revo tranny doesn't fit the g2r xbraces properly so I went with the tmaxx tranny and was working on a center diff solution for the tmaxx trans. Then Traxxas comes out with the 3.3 tranny, which uses at the same gears as the revo tranny, and they solved my problem. All I had to do is make the motor mount and adjust the rear shaft a bit. The motor mount actually works better on this tranny because I can utilize several of the diff case screw/mount points for motor mount stability. You can see in the first pic, I'm using black plastic spacers between the tranny mount and the motor plate. I messed up the one on the left so the spacer won't align properly. :031: Its not really even needed so I'll look at correcting it later. I also developed an easier method to mount a plate on the revo type cases. I'm not sure why I didn't think of this before.
Cheers
Ha Ha
