Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
04.22.2012, 07:42 AM
Thanks for the kind words - and I'll pass them along to Daniel.
I was reading back through the thread and I noticed the lexan you put on top of the shock piston for the variable damping. I like the idea and will experiment with it on my build. It probably helped alot when using LST springs on a fairly heavy rig as it adds compression damping without effecting rebound much. But I wonder if now the springs are strong enough to not require that added compression damping and placing them under the piston to add rebound damping.
That's exactly why I modified the piston - because even the RC-raven springs were not strong enough for these larger trucks. So, I may just get rid of the lexan pieces if I'm not happy with the suspension (I hadn't considered your idea of putting them underneath to add rebound damping - but I'll keep it in mind) . I put thicker oil in the shocks yesterday and like the way it feels just sitting here pushing on it - but I'll have to get it out again and test it.
