04.26.2012, 11:05 AM
Sadly I found them weak - I kept snapping the shaft at the rod end.
LSTII it is then.
Big House
Big House's Avatar
LSTII it is then. - 04.26.2012, 12:32 PM
Arct1k,
I appreciate the info. Upon further investigation and using your pics, it is an LSTII. I guess I can refine the parts search. The only thing with the center spool out of the GTP, the cups are a bit short so I will need a longer rear CVD. I have a Mayhem ST with a beefy rear center shaft. If can find that I will be golden.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
04.26.2012, 01:14 PM
Originally Posted by Big House View Post
Arct1k,
I used a dm-1/gtp spool in my E-LST. (I believe they use the same spool?) Anyway, the shafts barely sit in the cups but it does work. They are actually sitting in the cups farther than the shafts sat in the lst transmission. Pic:
Big House
Big House's Avatar
04.26.2012, 01:52 PM
P,
What motor are you using to push your truck? The amount of metal on this thing really concerns me. It is going to be well powered but the lighter the better.
CF Losi LST2
This job just got bigger.....
Big House
Big House's Avatar
This job just got bigger..... - 04.26.2012, 07:39 PM
But will be even more rewarding...I cannot find the Carbon parts I want so they will have to be hand cut. the flat pieces. The front plate will be replaced. I love these type of builds. Firsts new parts should arrive tomorrow. I will mock up the center diff assembly and motor mount. It will be a carbon fiber aluminum angle two piece.
CF Losi LST2
04.26.2012, 09:02 PM
P,
tekno neu 1515 2.5d, 1650kv. My truck is full aluminum and it tosses it around with no problems. The 1717 you plan on using is plenty of motor.
Big House
Big House's Avatar
04.26.2012, 10:44 PM
That is the idea. I am going for the extra wide wheels so thew extra motor will definitively help there. I hope the CF diet will get it down to 10 lbs with the motor and lipos.
CF Losi LST2
Center diff is in...
Big House
Big House's Avatar
Center diff is in... - 04.28.2012, 12:00 AM
The Ofna parts worked without a hitch. The diff is mocked up and if fully functional with the existing aluminum pieces. Once the CF plate comes in, It will be cut to match. Here are a few pics of the center diff in place.
Name:	Center diff 1.jpg
ID:	10330   Click image for larger version
Name:	Center diff 2.jpg
CF Losi LST2
