Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Kcaz25
Kcaz25's Avatar
04.30.2012, 08:39 PM
Okay here is the thing. I really need advice on this. I want to flip my center diff assembly. This will point the motor backwards on the opposite side of the chassis. This will also allow me to move the battery to the front on the opposite side as it sits now. This is the setup that Monster Mike has on his conversions in the store.
Now here is the deal- I will need to make new clearance for the spur gear. Can I raise the center diff assembly with carbon fiber without a problem? SO in other words I will not make a new hole in the chassis but will lift the teeth of the spur away from the chassis with a carbon fiber plate. Will this cause a problem with rocks or other things?
CLICKis like what I'm talking about! And where I got the idea!
I made a CF center diff spacer today, which is needed because the diff is flipped around. It covers the stock spur clearance hole, and allows clearance for the spur on the opposite side. It raises the center diff by 3mm.
-Zack
SnoopMaxx
SnoopMaxx's Avatar
05.04.2012, 03:40 PM
-Zack
I see you answered your own question
with the answer I was about to type ......
Morten SnoopMaxx
Never to old to play
c",)
